Zum Hauptinhalt wechseln
Acer Chromebook Spin 511 (C741L) N20Q8 I/O Board Replacement
Was du brauchst
  1. Acer Chromebook Spin 511 (C741L) N20Q8 I/O Board Replacement, Back Cover: Schritt 1, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 I/O Board Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the eleven 2.4 mm screws securing the back plate and internals of the Chromebook using a Phillips #1 screwdriver.
  2. Acer Chromebook Spin 511 (C741L) N20Q8 I/O Board Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 I/O Board Replacement: Schritt 2, Bild 2 von 2
    • Use an opening pick to remove the backplate of the laptop revealing the internals of the Chromebook.
  3. Acer Chromebook Spin 511 (C741L) N20Q8 I/O Board Replacement, Battery: Schritt 3, Bild 1 von 3 Acer Chromebook Spin 511 (C741L) N20Q8 I/O Board Replacement, Battery: Schritt 3, Bild 2 von 3 Acer Chromebook Spin 511 (C741L) N20Q8 I/O Board Replacement, Battery: Schritt 3, Bild 3 von 3
    • Gently remove the electrical tape from the battery.
    • Detach the colored wires from the wire connector on the motherboard.
    • Remove the battery from the laptop.
  4. Acer Chromebook Spin 511 (C741L) N20Q8 I/O Board Replacement, I/O Board: Schritt 4, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 I/O Board Replacement, I/O Board: Schritt 4, Bild 2 von 2
    • Remove the four 2.4 mm screws from the hinge in the upper left corner using a Phillips #1 screwdriver.
    • Flip the gray hinges up.
  5. Acer Chromebook Spin 511 (C741L) N20Q8 I/O Board Replacement: Schritt 5, Bild 1 von 1
    • Remove the metal plate above the I/O board.
  6. Acer Chromebook Spin 511 (C741L) N20Q8 I/O Board Replacement: Schritt 6, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 I/O Board Replacement: Schritt 6, Bild 2 von 2
    • Detach the two connectors attached to the motherboard.
  7. Acer Chromebook Spin 511 (C741L) N20Q8 I/O Board Replacement: Schritt 7, Bild 1 von 1
    • Remove the I/O board from the laptop.
Abschluss
Lauryn F
710 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 66
