Einleitung
If several keys or the mouse/touch pad are unresponsive, or the entire keyboard on your Acer Chromebook (Spin 511 (C741L) N20Q8) stops registering your input, then a replacement is needed to be fully functional again.
Ensure that your laptop is powered down for this replacement, then follow this guide.
Was du brauchst
Remove the eleven 2.4 mm screws securing the back plate and internals of the Chromebook using a Phillips #1 screwdriver.
Use an opening pick to remove the backplate of the laptop revealing the internals of the Chromebook.
Gently remove the electrical tape from the battery.
Detach the colored wires from the wire connector on the motherboard.
Remove the battery from the laptop.
Remove the six 2.4 mm screws from the hinges using a Phillips #1 screwdriver.
Flip up the hinges on each side that were previously secured down by the screws.
Detach the connector from the motherboard.
Carefully remove the pin connector containing the black, white, and red wires from its socket.
