Zum Hauptinhalt wechseln
Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement
Was du brauchst
  1. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the eleven 2.4 mm screws securing the back plate and internals of the Chromebook using a Phillips #1 screwdriver.
  2. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use an opening pick to remove the backplate of the laptop revealing the internals of the Chromebook.
  3. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Battery: Schritt 3, Bild 1 von 3 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Battery: Schritt 3, Bild 2 von 3 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Battery: Schritt 3, Bild 3 von 3
    • Gently remove the electrical tape from the battery.
    • Detach the colored wires from the wire connector on the motherboard.
    • Remove the battery from the laptop.
  4. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 3 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 3 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement, Motherboard: Schritt 4, Bild 3 von 3
    • Remove the six 2.4 mm screws from the hinges using a Phillips #1 screwdriver.
    • Flip the gray hinges up.
  5. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: Schritt 5, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the two metal plates that were previously held down by each hinge.
  6. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: Schritt 6, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Detach the connector from the motherboard.
  7. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: Schritt 7, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Gently remove the blue, yellow, and black wires from their connectors.
  8. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: Schritt 8, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove the tape from the black connector and gently remove it from the socket.
  9. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: Schritt 9, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Carefully remove the pin connector containing the black, white, and red wires from its socket.
  10. Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: Schritt 10, Bild 1 von 3 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: Schritt 10, Bild 2 von 3 Acer Chromebook Spin 511 (C741L) N20Q8 Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Detach the long connector from the socket.
    • Remove the motherboard from the device.
Abschluss
Lauryn F
710 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 20
Insgesamt: 96
