Zum Hauptinhalt wechseln
Acer Chromebook cb3-532-c47c Display Assembly Replacement
Was du brauchst
  1. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Back Panel: Schritt 1, Bild 1 von 2 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c Display Assembly Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook cb3-532-c47c Display Assembly Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the battery cable: Schritt 3, Bild 1 von 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Unplug the WiFi Antenna Connectors: Schritt 4, Bild 1 von 2 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Unplug the WiFi Antenna Connectors: Schritt 4, Bild 2 von 2
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the Black WiFi Wire: Schritt 5, Bild 1 von 2 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the Black WiFi Wire: Schritt 5, Bild 2 von 2
    • Deroute the black wifi wire from its slot in the palm rest.
  6. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the White WiFi Wire: Schritt 6, Bild 1 von 2 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the White WiFi Wire: Schritt 6, Bild 2 von 2
    • Deroute the white wifi wire from the slot in the palm rest.
  7. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: Schritt 7, Bild 1 von 3 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: Schritt 7, Bild 2 von 3 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: Schritt 7, Bild 3 von 3
    • Pull the end of the display cable attached to the motherboard straight up to remove.
    • Rotate the cable out away from the motherboard.
  8. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove Right Hinge Screws: Schritt 8, Bild 1 von 1
    • Remove the two screws from the right hinge.
  9. Acer Chromebook cb3-532-c47c Display Assembly Replacement: Schritt 9, Bild 1 von 2 Acer Chromebook cb3-532-c47c Display Assembly Replacement: Schritt 9, Bild 2 von 2
    • Insert a screwdriver or spudger under the hinge to get it started then rotate it open by hand as far as possible.
  10. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove Left Hinge Screws: Schritt 10, Bild 1 von 1
    • Remove the two screws from the left hinge.
  11. Acer Chromebook cb3-532-c47c Display Assembly Replacement: Schritt 11, Bild 1 von 2 Acer Chromebook cb3-532-c47c Display Assembly Replacement: Schritt 11, Bild 2 von 2
  12. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: Schritt 12, Bild 1 von 3 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: Schritt 12, Bild 2 von 3 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: Schritt 12, Bild 3 von 3
    • Lift the palm rest assembly from the front then slide it away from the hinges slightly to remove the assembly from the display.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jerry Wheeler
57.899 Reputation
69 Anleitungen geschrieben
Oregonians Mitglied von Oregonians
Community
7 Mitglieder
176 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 292
