Zum Hauptinhalt wechseln
Acer Chromebook cb3-532-c47c I/O Board Replacement
Was du brauchst
  1. Acer Chromebook cb3-532-c47c I/O Board Replacement, Back Panel: Schritt 1, Bild 1 von 2 Acer Chromebook cb3-532-c47c I/O Board Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c I/O Board Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook cb3-532-c47c I/O Board Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c I/O Board Replacement, Remove the battery cable: Schritt 3, Bild 1 von 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c I/O Board Replacement, Remove Right Hinge Screws: Schritt 4, Bild 1 von 1
    • Remove the two screws from the right hinge.
  5. Acer Chromebook cb3-532-c47c I/O Board Replacement: Schritt 5, Bild 1 von 2 Acer Chromebook cb3-532-c47c I/O Board Replacement: Schritt 5, Bild 2 von 2
    • Insert a screwdriver or spudger under the hinge to get it started then rotate it open by hand as far as possible.
  6. Acer Chromebook cb3-532-c47c I/O Board Replacement, Remove the LED Cable: Schritt 6, Bild 1 von 2 Acer Chromebook cb3-532-c47c I/O Board Replacement, Remove the LED Cable: Schritt 6, Bild 2 von 2
    • Flip up the latch on the cable going from the I/O board to the LED board.
  7. Acer Chromebook cb3-532-c47c I/O Board Replacement: Schritt 7, Bild 1 von 2 Acer Chromebook cb3-532-c47c I/O Board Replacement: Schritt 7, Bild 2 von 2
    • Grasp the ribbon cable and pull it straight out to the right.
  8. Acer Chromebook cb3-532-c47c I/O Board Replacement, Remove the Motherboard Cable: Schritt 8, Bild 1 von 2 Acer Chromebook cb3-532-c47c I/O Board Replacement, Remove the Motherboard Cable: Schritt 8, Bild 2 von 2
    • Flip up the latch on the cable from the I/O board to the motherboard.
  9. Acer Chromebook cb3-532-c47c I/O Board Replacement: Schritt 9, Bild 1 von 2 Acer Chromebook cb3-532-c47c I/O Board Replacement: Schritt 9, Bild 2 von 2
    • Grasp the ribbon cable by the blue plastic reinforcement and pull the cable straight out to the right.
  10. Acer Chromebook cb3-532-c47c I/O Board Replacement, Remove the Retaining Screw: Schritt 10, Bild 1 von 1
    • Remove the single screw securing the I/O board.
  11. Acer Chromebook cb3-532-c47c I/O Board Replacement: Schritt 11, Bild 1 von 1
    • Remove the I/O board.
    • When reinstalling, be sure the hinge goes above the I/O board, not below it.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Jerry Wheeler
72.362 Reputation
71 Anleitungen geschrieben
Oregonians Mitglied von Oregonians
Community
8 Mitglieder
191 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 252
