Zum Hauptinhalt wechseln
Acer Chromebook cb3-532-c47c LED Board Replacement
Was du brauchst
  1. Acer Chromebook cb3-532-c47c LED Board Replacement, Back Panel: Schritt 1, Bild 1 von 2 Acer Chromebook cb3-532-c47c LED Board Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c LED Board Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook cb3-532-c47c LED Board Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the battery cable: Schritt 3, Bild 1 von 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c LED Board Replacement, Disconnect the LED board: Schritt 4, Bild 1 von 2 Acer Chromebook cb3-532-c47c LED Board Replacement, Disconnect the LED board: Schritt 4, Bild 2 von 2
    • Flip the retaining latch up with a spudger.
  5. Acer Chromebook cb3-532-c47c LED Board Replacement: Schritt 5, Bild 1 von 2 Acer Chromebook cb3-532-c47c LED Board Replacement: Schritt 5, Bild 2 von 2
    • Pull the cable straight out away from the front of the computer.
  6. Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: Schritt 6, Bild 1 von 3 Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: Schritt 6, Bild 2 von 3 Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: Schritt 6, Bild 3 von 3
    • Remove the single retaining screw securing the LED board.
    • Remove the board.
    • When reassembling, ensure the board is seated on the guide pin before reinstalling the retaining screw.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Jerry Wheeler
72.362 Reputation
71 Anleitungen geschrieben
Oregonians Mitglied von Oregonians
Community
8 Mitglieder
191 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 92
