Einleitung
The LED board has one purpose, to hold the two LEDs visible from the front of the computer. Issues with the LED board itself are extremely rare.
Was du brauchst
Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
Remove the single retaining screw securing the LED board.
Remove the board.
When reassembling, ensure the board is seated on the guide pin before reinstalling the retaining screw.
Eine weitere Person hat diese Anleitung absolviert.
