Zum Hauptinhalt wechseln
Acer Chromebook cb3-532-c47c WiFi Card Replacement
Was du brauchst
  1. Acer Chromebook cb3-532-c47c WiFi Card Replacement, Back Panel: Schritt 1, Bild 1 von 2 Acer Chromebook cb3-532-c47c WiFi Card Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c WiFi Card Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook cb3-532-c47c WiFi Card Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c WiFi Card Replacement, Remove the battery cable: Schritt 3, Bild 1 von 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c WiFi Card Replacement, Unplug the WiFi Antenna Connectors: Schritt 4, Bild 1 von 2 Acer Chromebook cb3-532-c47c WiFi Card Replacement, Unplug the WiFi Antenna Connectors: Schritt 4, Bild 2 von 2
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook cb3-532-c47c WiFi Card Replacement, WiFi Card: Schritt 5, Bild 1 von 3 Acer Chromebook cb3-532-c47c WiFi Card Replacement, WiFi Card: Schritt 5, Bild 2 von 3 Acer Chromebook cb3-532-c47c WiFi Card Replacement, WiFi Card: Schritt 5, Bild 3 von 3
    • Using the Phillips #0 screwdriver, remove the single 6 mm screw securing the Wi-Fi card.
    • Pull the Wi-Fi card straight out of the motherboard and remove it from the device.
Abschluss
Jerry Wheeler
72.310 Reputation
71 Anleitungen geschrieben
Oregonians Mitglied von Oregonians
Community
8 Mitglieder
189 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 25
Insgesamt: 204
