Zum Hauptinhalt wechseln
Acer E5-571-54FL Hard drive Replacement
Was du brauchst
  1. Acer E5-571-54FL Hard drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power down the laptop prior to beginning.
    • Turn the laptop over with the battery closest to your body.
  2. Acer E5-571-54FL Hard drive Replacement: Schritt 2, Bild 1 von 2 Acer E5-571-54FL Hard drive Replacement: Schritt 2, Bild 2 von 2
    • Insert the pointed end of a spudger into the battery release.
    • Slide the release gently all the way to the left.
    • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  3. Acer E5-571-54FL Hard drive Replacement: Schritt 3, Bild 1 von 2 Acer E5-571-54FL Hard drive Replacement: Schritt 3, Bild 2 von 2
    • Place your hands on each end of the battery.
    • Pull the battery towards your body to remove it.
  4. Acer E5-571-54FL Hard drive Replacement, Keyboard: Schritt 4, Bild 1 von 1
    • Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
  5. Acer E5-571-54FL Hard drive Replacement: Schritt 5, Bild 1 von 1
    • Rotate the laptop 180 degrees so that the battery compartment is now furthest away from your body.
  6. Acer E5-571-54FL Hard drive Replacement: Schritt 6, Bild 1 von 1
    • Turn the laptop over so that you can easily open the screen to a vertical position.
  7. Acer E5-571-54FL Hard drive Replacement: Schritt 7, Bild 1 von 1
    • Put your fingers under the top of the keyboard assembly directly below the Acer logo.
    • Carefully pull up on the center until you hear the tabs disengage from the bottom.
  8. Acer E5-571-54FL Hard drive Replacement: Schritt 8, Bild 1 von 3 Acer E5-571-54FL Hard drive Replacement: Schritt 8, Bild 2 von 3 Acer E5-571-54FL Hard drive Replacement: Schritt 8, Bild 3 von 3
    • Work your way around the seam with the plastic opening tool carefully prying the base and top cover apart.
    • If you have difficulty with the plastic opening tool, use a metal spudger but be more cautious to not damage or mar your laptop case.
  9. Acer E5-571-54FL Hard drive Replacement: Schritt 9, Bild 1 von 1
    • When the two halves are separated, carefully lift up the front of the keyboard and touchpad assembly.
    • You will see three ribbon cables attached to the motherboard.
  10. Acer E5-571-54FL Hard drive Replacement: Schritt 10, Bild 1 von 3 Acer E5-571-54FL Hard drive Replacement: Schritt 10, Bild 2 von 3 Acer E5-571-54FL Hard drive Replacement: Schritt 10, Bild 3 von 3
    • Closest to the ribbon cable on the zero insertion force (ZIF) connector is a white locking tab.
    • Carefully lift up on the locking tab with the plastic opening tool to release the ribbon cable. (Picture 2)
    • Remove the ribbon cable from the connector.
  11. Acer E5-571-54FL Hard drive Replacement: Schritt 11, Bild 1 von 3 Acer E5-571-54FL Hard drive Replacement: Schritt 11, Bild 2 von 3 Acer E5-571-54FL Hard drive Replacement: Schritt 11, Bild 3 von 3
    • Closest to the ribbon cable on the ZIF connector is a black locking tab.
  12. Acer E5-571-54FL Hard drive Replacement: Schritt 12, Bild 1 von 3 Acer E5-571-54FL Hard drive Replacement: Schritt 12, Bild 2 von 3 Acer E5-571-54FL Hard drive Replacement: Schritt 12, Bild 3 von 3
    • On each side of the large connector there are two white tabs.
    • Carefully push away from you with the plastic opening tool on each white tab to release the cable. (Picture 2)
  13. Acer E5-571-54FL Hard drive Replacement: Schritt 13, Bild 1 von 3 Acer E5-571-54FL Hard drive Replacement: Schritt 13, Bild 2 von 3 Acer E5-571-54FL Hard drive Replacement: Schritt 13, Bild 3 von 3
    • Once all three ribbon cables are disconnected, lift off the top cover with the keyboard and touchpad.
  14. Acer E5-571-54FL Hard drive Replacement, Hard drive: Schritt 14, Bild 1 von 2 Acer E5-571-54FL Hard drive Replacement, Hard drive: Schritt 14, Bild 2 von 2
    • Locate the hard drive and its carriage at the lower right corner of the laptop.
    • Release the USB port ribbon cable by using the plastic opening tool to carefully lift up the black locking tab of the ZIF connector.
    • Move the USB port ribbon cable to the side.
  15. Acer E5-571-54FL Hard drive Replacement: Schritt 15, Bild 1 von 2 Acer E5-571-54FL Hard drive Replacement: Schritt 15, Bild 2 von 2
    • Use a #0 Phillips screwdriver to remove the two 4mm screws securing the hard drive carriage in place.
  16. Acer E5-571-54FL Hard drive Replacement: Schritt 16, Bild 1 von 1
    • Hold the right side of the laptop in place with your right hand.
    • Put the fingers of your left hand along the top edge of the hard drive carriage.
    • Push the hard drive carriage towards your right hand to disconnect it from the motherboard.
    • This procedure may require more force then other procedures.
  17. Acer E5-571-54FL Hard drive Replacement: Schritt 17, Bild 1 von 2 Acer E5-571-54FL Hard drive Replacement: Schritt 17, Bild 2 von 2
    • Lift up the hard drive carriage on the edge closest to your body to remove it.
    • If doing the motherboard replacement guide, skip the next step.
  18. Acer E5-571-54FL Hard drive Replacement: Schritt 18, Bild 1 von 3 Acer E5-571-54FL Hard drive Replacement: Schritt 18, Bild 2 von 3 Acer E5-571-54FL Hard drive Replacement: Schritt 18, Bild 3 von 3
    • Locate the two 3 mm Phillips screws holding the hard drive into the carriage. There is one screw on each side of the carriage.
    • Hold the hard drive carriage with your non-dominant hand along one side. Ensure one of the Phillips screws is visible.
    • Using a #0 Phillips screwdriver, remove the 3 mm screw to release the side of the hard drive from the carriage.
    • Repeat the two previous bullet marks to remove the second 3 mm Phillips screw. This should also free the hard drive from the carriage.
Abschluss
Aaron Weissman
1.004 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team S3-G8, Bailey Fall 2017 Mitglied von UMass Dartmouth, Team S3-G8, Bailey Fall 2017
UMASSD-BAILEY-F17S3G8
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 368
