Einleitung
If your keyboard or trackpad no longer respond, this guide will help you access them. Follow each step to minimize damage to your laptop and gain access to the interior.
Was du brauchst
Power down the laptop prior to beginning.
Turn the laptop over with the battery closest to your body.
Insert the pointed end of a spudger into the battery release.
Slide the release gently all the way to the left.
Place your hands on each end of the battery.
Pull the battery towards your body to remove it.
Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
Rotate the laptop 180 degrees so that the battery compartment is now furthest away from your body.
Turn the laptop over so that you can easily open the screen to a vertical position.
Put your fingers under the top of the keyboard assembly directly below the Acer logo.
Carefully pull up on the center until you hear the tabs disengage from the bottom.
Work your way around the seam with the plastic opening tool carefully prying the base and top cover apart.
When the two halves are separated, carefully lift up the front of the keyboard and touchpad assembly.
You will see three ribbon cables attached to the motherboard.
Closest to the ribbon cable on the zero insertion force (ZIF) connector is a white locking tab.
Carefully lift up on the locking tab with the plastic opening tool to release the ribbon cable. (Picture 2)
Remove the ribbon cable from the connector.
Closest to the ribbon cable on the ZIF connector is a black locking tab.
On each side of the large connector there are two white tabs.
Carefully push away from you with the plastic opening tool on each white tab to release the cable. (Picture 2)
Once all three ribbon cables are disconnected, lift off the top cover with the keyboard and touchpad.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
hi there , i have a question regarding me having an issue with the keyboard ribbon cable . everytime I reconnect the ribbon cable differents keys stop working or no keys works at all . but if I left the keyboard panel and cable is well extended the whole keys are back working again .
the cable pins are connected correctly I don’t thing the issue is related to the connector end . hope someone can help
Maybe the issue is with the keyboard ribbon cable itself? Or possibly how it is seated in the connector? If it is slightly askew, some of the issues you describe can happen. Try to make sure the cable is seated fully into the connector and as square to the connector as possible. Good luck.
