Zum Hauptinhalt wechseln
Acer E5-571-54FL Optical Drive Replacement
Was du brauchst
  1. Acer E5-571-54FL Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power down the laptop prior to beginning.
    • Turn the laptop over with the battery closest to your body.
  2. Acer E5-571-54FL Optical Drive Replacement: Schritt 2, Bild 1 von 2 Acer E5-571-54FL Optical Drive Replacement: Schritt 2, Bild 2 von 2
    • Insert the pointed end of a spudger into the battery release.
    • Slide the release gently all the way to the left.
    • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  3. Acer E5-571-54FL Optical Drive Replacement: Schritt 3, Bild 1 von 2 Acer E5-571-54FL Optical Drive Replacement: Schritt 3, Bild 2 von 2
    • Place your hands on each end of the battery.
    • Pull the battery towards your body to remove it.
  4. Acer E5-571-54FL Optical Drive Replacement, Optical Drive: Schritt 4, Bild 1 von 1
    • Remove the single screw that holds the optical drive in place using the Phillips #0 screwdriver.
  5. Acer E5-571-54FL Optical Drive Replacement: Schritt 5, Bild 1 von 3 Acer E5-571-54FL Optical Drive Replacement: Schritt 5, Bild 2 von 3 Acer E5-571-54FL Optical Drive Replacement: Schritt 5, Bild 3 von 3
    • Slide out the old optical drive and remove it from the device.
Abschluss
Jennifer Hancock
325 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 438
