Einleitung
Replace the motherboard in a Acer Iconia A1-810.
Was du brauchst
Remove the back cover by lifting with a plastic opening tool, below the camera button slot.
Pinch the sides of the white resistor to safely remove it without damaging it or yourself.
Use a Phillips #000 screwdriver to remove the screws around the perimeter of the motherboard.
Disconnect the resistor attached to the orange tab by sliding the tail out.
Pry open the orange tab near the top left corner.
Disconnect all cords, wires, and resistors from the motherboard using tweezers.
Continue to disconnect all resistors attached from the motherboard, using tweezers.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
Can you replace the mini USB charger port without replacing entire motherboard and losing data?
