Zum Hauptinhalt wechseln
Acer Iconia A1-830 Battery Replacement
Was du brauchst
  1. Acer Iconia A1-830 Battery Replacement, Disassembling Acer Iconia A1-830 Back Panel: Schritt 1, Bild 1 von 2 Acer Iconia A1-830 Battery Replacement, Disassembling Acer Iconia A1-830 Back Panel: Schritt 1, Bild 2 von 2
    • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
    • Shut down your Acer Iconia A1-830.
    • Remove any cables or exterior covers from your tablet.
    • Place it on your work space, with the screen facing up.
  2. Acer Iconia A1-830 Battery Replacement: Schritt 2, Bild 1 von 2 Acer Iconia A1-830 Battery Replacement: Schritt 2, Bild 2 von 2
    • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
    • Do not try to pry apart the top edge on the front side near the front-facing camera.
  3. Acer Iconia A1-830 Battery Replacement, Battery: Schritt 3, Bild 1 von 2 Acer Iconia A1-830 Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
  4. Acer Iconia A1-830 Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery cable by lifting it up with the pointy end of the black nylon spudger.
  5. Acer Iconia A1-830 Battery Replacement: Schritt 5, Bild 1 von 2 Acer Iconia A1-830 Battery Replacement: Schritt 5, Bild 2 von 2
    • Un-stick the battery from the metal plate using the black nylon spudger.
    • Be careful not to puncture the battery while removing it.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 4-6, Catania Fall 2015 Mitglied von UMass Dartmouth, Team 4-6, Catania Fall 2015
UMASSD-CATANIA-F15S4G6
3 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
thnks is goood
mo7tarif1997 - Antwort
Is it okay if the battery bends a slight bit when prying it off?
Doof - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 9,139
