Zum Hauptinhalt wechseln
Acer Iconia A100 3G Antenna Replacement
Was du brauchst
  1. Acer Iconia A100 3G Antenna Replacement, Battery: Schritt 1, Bild 1 von 1
    • Start at any side of the tablet.
    • Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
    • Work your way around the tablet.
    • There are four side pieces in total.
  2. Acer Iconia A100 3G Antenna Replacement: Schritt 2, Bild 1 von 1
    • Remove the five 4 mm screws from the edges of the tablet with a Phillips #00 screwdriver.
  3. Acer Iconia A100 3G Antenna Replacement: Schritt 3, Bild 1 von 1
    • Carefully separate the back piece from the device using a plastic opening tool.
    • Remember to open along the entire perimeter of the tablet.
  4. Acer Iconia A100 3G Antenna Replacement: Schritt 4, Bild 1 von 1
    • Turn the tablet over so that the battery is facing upwards.
    • Remove the four 4mm screws located around the battery.
  5. Acer Iconia A100 3G Antenna Replacement: Schritt 5, Bild 1 von 2 Acer Iconia A100 3G Antenna Replacement: Schritt 5, Bild 2 von 2
    • Use the tip of a plastic spudger or opening tool to gently push the connector head out of its socket.
    • Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
    • Be sure to not have any water around the device while removing the battery.
    • Be sure to be cautious while removing the battery and remove carefully; avoid ripping the wires attached to the battery.
  6. Acer Iconia A100 3G Antenna Replacement, I/O Board: Schritt 6, Bild 1 von 1
    • Gently peel off any tape securing the FPC to the main plate.
  7. Acer Iconia A100 3G Antenna Replacement: Schritt 7, Bild 1 von 3 Acer Iconia A100 3G Antenna Replacement: Schritt 7, Bild 2 von 3 Acer Iconia A100 3G Antenna Replacement: Schritt 7, Bild 3 von 3
    • Locate the two connectors at each end of the FPC.
    • Use the flat edge of a spudger tool or your fingernail to gently pry each connector straight upwards out of its socket, then remove the FPC cable from the unit.
    • While a metal spudger tool is shown here, it is best to use a plastic spudger / opening tool when possible, and only use a metal spudger as a last resort!
    • You should now see the yellow-colored strip on the metal base marking the location of the FPC
  8. Acer Iconia A100 3G Antenna Replacement: Schritt 8, Bild 1 von 1
    • Locate the L-shaped I/O Board.
    • Locate the gray 3G Antenna wire.
    • If the gray 3G Antenna wire is connected to your I/O Board, disconnect it. If for some reason the 3G Antenna wire is already disconnected from the I/O Board (as it was in this device) simply lift it out of the way.
  9. Acer Iconia A100 3G Antenna Replacement: Schritt 9, Bild 1 von 2 Acer Iconia A100 3G Antenna Replacement: Schritt 9, Bild 2 von 2
    • Locate the microphone cable.
    • You should be able to gently pull it out of its socket using only your fingers.
    • The spudger is used in the photo merely to hold up / identify the disconnected mic cable head.
  10. Acer Iconia A100 3G Antenna Replacement: Schritt 10, Bild 1 von 3 Acer Iconia A100 3G Antenna Replacement: Schritt 10, Bild 2 von 3 Acer Iconia A100 3G Antenna Replacement: Schritt 10, Bild 3 von 3
    • Locate the light sensor connector.
    • Use the tip of a spudger or your fingernail to lift up and flip the small retaining flap on the connector. The light sensor ribbon cable should now be free, so simply pull it out.
    • This is a ZIF (zero insertion force) connector, which requires no force to remove / plug in the connector.
    • Please make sure you lift up on the small retaining flap on the connector, not the connector itself!
    • Use a Phillips #00 screwdriver to unscrew the single 3.0mm Phillips screw next to the light sensor connector.
  11. Acer Iconia A100 3G Antenna Replacement: Schritt 11, Bild 1 von 2 Acer Iconia A100 3G Antenna Replacement: Schritt 11, Bild 2 von 2
    • Carefully lift the I/O Board off the device.
  12. Acer Iconia A100 3G Antenna Replacement, 3G Antenna: Schritt 12, Bild 1 von 3 Acer Iconia A100 3G Antenna Replacement, 3G Antenna: Schritt 12, Bild 2 von 3 Acer Iconia A100 3G Antenna Replacement, 3G Antenna: Schritt 12, Bild 3 von 3
    • Use the flat end of a spudger to pry the gold connector of the antenna cable straight up from the unit.
    • While a metal spudger tool is shown here, it is best to use a plastic spudger/opening tool when possible, and only use a metal spudger as a last resort!
    • With the 3G Antenna cable disconnected from the device, lift the 3G Antenna module out and remove it from the device.
Abschluss
Nacarri Murphy
106 Reputation
1 Anleitung geschrieben
IUPUI, Team S1-G4, Harley Spring 2017 Mitglied von IUPUI, Team S1-G4, Harley Spring 2017
IUPUI-HARLEY-S17S1G4
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 225
