Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
A step-by-step guide that illustrates the necessary precautions for replacing a battery for the Acer Iconia A100 tablet.
  1. Start at any side of the tablet.
    • Start at any side of the tablet.
    • Begin to take apart the tablet ,with a plastic opening tool, along the sides of the tablet.
    • Work your way around the tablet.
    • There are four side pieces in total.
  2. Placed on each end of the tablet are 4mm Philips screws.
    • Placed on each end of the tablet are 4mm Philips screws.
    • Unscrew the 4mm Phillips screws with a Phillips #00 Screwdriver.
    • There are five 4.0mm screws in total (including the 4mm Phillips screw at the bottom of the tablet).
  3. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  4. Carefully separate the back piece from the device using a plastic opening tool.
    • Carefully separate the back piece from the device using a plastic opening tool.
    • Remember to open along the entire perimeter of the tablet.
  5. Turn the tablet over to locate the battery.
    • Turn the tablet over to locate the battery.
    • Locate the large blue and black object at the bottom of the tablet with the plus and minus sign.
  6. Unscrew the 4mm screws located around the battery.
    • Unscrew the 4mm screws located around the battery.
    • There are five in total.
  7. Locate the battery cables and the tip of a plastic spudger or opening tool to gently push the connector head out of its socket. Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
    • Locate the battery cables and the tip of a plastic spudger or opening tool to gently push the connector head out of its socket.
    • Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
    • Be sure to not have any water around the device while removing the battery.
    • Be sure to be cautious while removing the battery and remove carefully; avoid ripping the wires attached to the battery.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Omar Acosta
526 Reputation
3 Anleitungen geschrieben
Sam Houston State, Team 13-3, Blackburne Winter 2015 Mitglied von Sam Houston State, Team 13-3, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S13G3
1 Mitglied
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 5
Insgesamt: 1,608
