Zum Hauptinhalt wechseln
Acer Iconia A100 Battery Replacement
Was du brauchst
  1. Acer Iconia A100 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Start at any side of the tablet.
    • Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
    • Work your way around the tablet.
    • There are four side pieces in total.
  2. Acer Iconia A100 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the five 4 mm screws from the edges of the tablet with a Phillips #00 screwdriver.
  3. Acer Iconia A100 Battery Replacement: Schritt 3, Bild 1 von 1
    • Carefully separate the back piece from the device using a plastic opening tool.
    • Remember to open along the entire perimeter of the tablet.
  4. Acer Iconia A100 Battery Replacement: Schritt 4, Bild 1 von 1
    • Turn the tablet over so that the battery is facing upwards.
    • Remove the four 4mm screws located around the battery.
  5. Acer Iconia A100 Battery Replacement: Schritt 5, Bild 1 von 2 Acer Iconia A100 Battery Replacement: Schritt 5, Bild 2 von 2
    • Use the tip of a plastic spudger or opening tool to gently push the connector head out of its socket.
    • Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
    • Be sure to not have any water around the device while removing the battery.
    • Be sure to be cautious while removing the battery and remove carefully; avoid ripping the wires attached to the battery.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Omar Acosta
526 Reputation
3 Anleitungen geschrieben
Sam Houston State, Team 13-3, Blackburne Winter 2015 Mitglied von Sam Houston State, Team 13-3, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S13G3
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,887
