Einleitung
If the sound from your speakers is distorted or absent, you may need to replace the speakers. This guide will show you the step-by-by process of removing or replacing the speakers module on your Acer Iconia Tab A100 device.
Was du brauchst
Start at any side of the tablet.
Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
Work your way around the tablet.
Remove the five 4 mm screws from the edges of the tablet with a Phillips #00 screwdriver.
Carefully separate the back piece from the device using a plastic opening tool.
Turn the tablet over so that the battery is facing upwards.
Remove the four 4mm screws located around the battery.
Use the tip of a plastic spudger or opening tool to gently push the connector head out of its socket.
Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
Locate the speakers module, which consists of 2 square black speakers connected by wires.
Locate the white and blue Home Key FFC ribbon cable between the speakers.
Use the tip of a spudger or opening tool to lift up and flip the small hinge on the connector. Then gently pull the FFC ribbon cable out its connector socket.
Locate the speaker cable. Use your fingers to pinch each side of the black head of the speaker cable, and gently pull it out of its socket.
Unscrew the 4mm Phillips screws securing the speakers module to the device using a Phillips #00 screwdriver.
Now both speakers should be free. Use the edge of a spudger tool to lift each speaker off the device, or use your hands to simultaneously lift each square black speaker off of the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
