Zum Hauptinhalt wechseln
Acer Iconia A110 Battery Replacement
Was du brauchst
  1. Acer Iconia A110 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Iconia A110 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before taking apart your tablet, make sure the device is powered off.
    • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
    • During this process, the volume button and/or power button may fall out.
  2. Acer Iconia A110 Battery Replacement: Schritt 2, Bild 1 von 3 Acer Iconia A110 Battery Replacement: Schritt 2, Bild 2 von 3 Acer Iconia A110 Battery Replacement: Schritt 2, Bild 3 von 3
    • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
  3. Acer Iconia A110 Battery Replacement: Schritt 3, Bild 1 von 3 Acer Iconia A110 Battery Replacement: Schritt 3, Bild 2 von 3 Acer Iconia A110 Battery Replacement: Schritt 3, Bild 3 von 3
    • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
    • You should hear the adhesive ripping as you do this.
    • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Andrea
757 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 3-42, Maness Spring 2014 Mitglied von Cal Poly, Team 3-42, Maness Spring 2014
CPSU-MANESS-S14S3G42
4 Mitglieder
Ein Kommentar
Where can you purchase the battery for acer iconia tab a110?
redd4167 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 11,265
