Zum Hauptinhalt wechseln
Einleitung
How to open the tablet and replace the battery pack.
This video is for replacing the touch screen and LCD display but in the beginning you can see how to open the back cover and how to separate the battery from the tablet. You don't need to remove the mother board.
Please SUBSCRIBE to my channel ツ
Ersatzteile
Keine Ersatzteile angegeben.
Einführungsvideo
  1. Switch-off the tablet. If you have a memory card inside, don't forget to remove it! Use a cutter and a plastic tool to remove the back cover.
    • Switch-off the tablet.
    • If you have a memory card inside, don't forget to remove it!
    • Use a cutter and a plastic tool to remove the back cover.
  2. Disconnect the battery connector. The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it . The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it .
    • Disconnect the battery connector.
    • The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it .
  3. Li-on Batteri Pack, 3.8V, 2640mAh
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
ZFix
166.755 Reputation
305 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
288 Mitglieder
820 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 6
Letzte 7 Tage: 14
Letzte 30 Tage: 68
Insgesamt: 18,744
