Zum Hauptinhalt wechseln
Acer Iconia B1-710 Screen Replacement
Was du brauchst
  1. Acer Iconia B1-710 Screen Replacement, Battery: Schritt 1, Bild 1 von 3 Acer Iconia B1-710 Screen Replacement, Battery: Schritt 1, Bild 2 von 3 Acer Iconia B1-710 Screen Replacement, Battery: Schritt 1, Bild 3 von 3
    • Open the back cover by prying the casing off with an opening tool.
    • Be careful to not pull pieces apart aggressively. There is a wire that could break.
  2. Acer Iconia B1-710 Screen Replacement: Schritt 2, Bild 1 von 3 Acer Iconia B1-710 Screen Replacement: Schritt 2, Bild 2 von 3 Acer Iconia B1-710 Screen Replacement: Schritt 2, Bild 3 von 3
    • Unplug the battery from the motherboard.
  3. Acer Iconia B1-710 Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery.
    • The battery is lightly glued in, so there may be some difficulty getting it out.
  4. Acer Iconia B1-710 Screen Replacement, Screen: Schritt 4, Bild 1 von 2 Acer Iconia B1-710 Screen Replacement, Screen: Schritt 4, Bild 2 von 2
    • Unscrew all five 3 mm #000 Phillips screws.
  5. Acer Iconia B1-710 Screen Replacement: Schritt 5, Bild 1 von 2 Acer Iconia B1-710 Screen Replacement: Schritt 5, Bild 2 von 2
    • Unplug the LCD ribbon.
  6. Acer Iconia B1-710 Screen Replacement: Schritt 6, Bild 1 von 2 Acer Iconia B1-710 Screen Replacement: Schritt 6, Bild 2 von 2
    • Unplug the orange ribbon.
  7. Acer Iconia B1-710 Screen Replacement: Schritt 7, Bild 1 von 3 Acer Iconia B1-710 Screen Replacement: Schritt 7, Bild 2 von 3 Acer Iconia B1-710 Screen Replacement: Schritt 7, Bild 3 von 3
    • Unplug the white wire from the motherboard.
    • Unplug the black wire from the motherboard.
  8. Acer Iconia B1-710 Screen Replacement: Schritt 8, Bild 1 von 1
    • Pull the motherboard off of the tablet.
  9. Acer Iconia B1-710 Screen Replacement: Schritt 9, Bild 1 von 1
    • Use a blow dryer to melt the glue holding the LCD display in place.
    • Patience is key. It will take a few minutes to melt the glue.
  10. Acer Iconia B1-710 Screen Replacement: Schritt 10, Bild 1 von 3 Acer Iconia B1-710 Screen Replacement: Schritt 10, Bild 2 von 3 Acer Iconia B1-710 Screen Replacement: Schritt 10, Bild 3 von 3
    • Peel the LCD display.
    • This piece is fragile and needs to be peeled with care.
    • Parts may be hot.
  11. Acer Iconia B1-710 Screen Replacement: Schritt 11, Bild 1 von 1
    • Use a blow dryer to melt the glue from the thin metal frame.
    • This piece is metal and will become hot during this process.
  12. Acer Iconia B1-710 Screen Replacement: Schritt 12, Bild 1 von 2 Acer Iconia B1-710 Screen Replacement: Schritt 12, Bild 2 von 2
    • Peel off the thin metal frame.
    • Be careful not to bend the frame as it is very thin.
  13. Acer Iconia B1-710 Screen Replacement: Schritt 13, Bild 1 von 1
    • Use a blow dryer to melt the glue between the metal frame and the screen.
    • The frame will get hot.
  14. Acer Iconia B1-710 Screen Replacement: Schritt 14, Bild 1 von 2 Acer Iconia B1-710 Screen Replacement: Schritt 14, Bild 2 von 2
    • Peel the frame from the screen.
    • Be careful when peeling the screen or it may sustain further damage.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ryan Weber
358 Reputation
3 Anleitungen geschrieben
IUPUI, Team S3-G5, Baechle Spring 2017 Mitglied von IUPUI, Team S3-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 12
Insgesamt: 936
