Zum Hauptinhalt wechseln
Acer Iconia B1-711 V1-711 Logic Board Replacement
Was du brauchst
Einführungsvideo
  1. Acer Iconia B1-711 V1-711 Logic Board Replacement, Back Cover: Schritt 1, Bild 1 von 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Back Cover: Schritt 1, Bild 2 von 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Switch-off the tablet.
    • Remove any SIM and/or Memory Card.
    • Start opening near to the Volume Up/Down buttons. It's more well to use a plastic opening tool to avoid damaging the cover.
    • When lifting the cover, be careful not to tear the Loudspeaker cable at the bottom right side.
    • Disconnect the Loudspeaker cable from the Logic board.
  2. Acer Iconia B1-711 V1-711 Logic Board Replacement: Schritt 2, Bild 1 von 2 Acer Iconia B1-711 V1-711 Logic Board Replacement: Schritt 2, Bild 2 von 2
    • Before doing anything, disconnect the battery.
  3. Acer Iconia B1-711 V1-711 Logic Board Replacement, Battery: Schritt 3, Bild 1 von 2 Acer Iconia B1-711 V1-711 Logic Board Replacement, Battery: Schritt 3, Bild 2 von 2
    • With a long plastic tool like a spudger, unstick the battery from the metal LCD shield.
    • Lithium Ion Battery Pack - 3.8V, 2710mAh
  4. Acer Iconia B1-711 V1-711 Logic Board Replacement, Audio Jack Connector: Schritt 4, Bild 1 von 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Audio Jack Connector: Schritt 4, Bild 2 von 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Audio Jack Connector: Schritt 4, Bild 3 von 3
    • Unscrew 2x Philips screws
    • Disconnect and remove the Audio Jack Board flex cable.
    • Remove the board with the Audio Jack Connector.
  5. Acer Iconia B1-711 V1-711 Logic Board Replacement, Camera: Schritt 5, Bild 1 von 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Camera: Schritt 5, Bild 2 von 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Camera: Schritt 5, Bild 3 von 3
    • Remove the Audio jack flex cable.
    • Remove the metal plate which is placed on the camera connector.
    • Disconnect the camera flex cable.
  6. Acer Iconia B1-711 V1-711 Logic Board Replacement: Schritt 6, Bild 1 von 1
    • Remove the camera.
  7. Acer Iconia B1-711 V1-711 Logic Board Replacement, Microphone: Schritt 7, Bild 1 von 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Microphone: Schritt 7, Bild 2 von 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Microphone: Schritt 7, Bild 3 von 3
    • Remove the tape from the microphone.
    • Disconnect the Microphone wires and remove the Microphone.
  8. Acer Iconia B1-711 V1-711 Logic Board Replacement, Logic Board: Schritt 8, Bild 1 von 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Logic Board: Schritt 8, Bild 2 von 3 Acer Iconia B1-711 V1-711 Logic Board Replacement, Logic Board: Schritt 8, Bild 3 von 3
    • Remove the green rubber and disconnect the touch screen flex cable.
    • Disconnect the 4 coaxial antenna cables (Wi-Fi, GPS, 3G).
    • Carefully unstuck the metal folio from the LCD display flex cable.
    • Remove the 3x Phillips screws.
  9. Acer Iconia B1-711 V1-711 Logic Board Replacement: Schritt 9, Bild 1 von 3 Acer Iconia B1-711 V1-711 Logic Board Replacement: Schritt 9, Bild 2 von 3 Acer Iconia B1-711 V1-711 Logic Board Replacement: Schritt 9, Bild 3 von 3
    • Lift the board from the side of the battery connector and turn it around the display connector on 360 degrees.
    • Be careful for the flex cable!
    • Disconnect the LCD display flex cable.
  10. Acer Iconia B1-711 V1-711 Logic Board Replacement: Schritt 10, Bild 1 von 2 Acer Iconia B1-711 V1-711 Logic Board Replacement: Schritt 10, Bild 2 von 2
    • This is the Logic board.
Abschluss
ZFix
191.308 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.534 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 948
