Zum Hauptinhalt wechseln
Acer Iconia B1-720 Battery Replacement
Was du brauchst
  1. Acer Iconia B1-720 Battery Replacement, Rear Case: Schritt 1, Bild 1 von 3 Acer Iconia B1-720 Battery Replacement, Rear Case: Schritt 1, Bild 2 von 3 Acer Iconia B1-720 Battery Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Battery Replacement: Schritt 2, Bild 1 von 3 Acer Iconia B1-720 Battery Replacement: Schritt 2, Bild 2 von 3 Acer Iconia B1-720 Battery Replacement: Schritt 2, Bild 3 von 3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Battery Replacement: Schritt 3, Bild 1 von 2 Acer Iconia B1-720 Battery Replacement: Schritt 3, Bild 2 von 2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Battery Replacement, Battery: Schritt 4, Bild 1 von 2 Acer Iconia B1-720 Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Peel back the plastic tape covering the battery connector.
  5. Acer Iconia B1-720 Battery Replacement: Schritt 5, Bild 1 von 1
    • Use the plastic opening tool to lift the battery off of the back panel. The adhesive used is strong so apply force during removal.
  6. Acer Iconia B1-720 Battery Replacement: Schritt 6, Bild 1 von 3 Acer Iconia B1-720 Battery Replacement: Schritt 6, Bild 2 von 3 Acer Iconia B1-720 Battery Replacement: Schritt 6, Bild 3 von 3
    • Lift the battery off of the panel gently. This will disconnect the battery connector from the motherboard.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Kervis Boston
479 Reputation
3 Anleitungen geschrieben
Michigan Tech, Team 1-1, Lauer Spring 2015 Mitglied von Michigan Tech, Team 1-1, Lauer Spring 2015
MTU-LAUER-S15S1G1
2 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Why the battery has a 4 pin connector? I tried to buy another generic battery but it got only 2 cables, don't know how to replace :(
Tadeu - Antwort
I just wanted to throw a red flag out there…I broke my connector off the motherboard trying to reinstall the four-pin connection…can anyone advise?
John Merritt - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 2,880
