Was du brauchst
Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
Slide the tool along until you have completely separated the rear cover.
If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
Once all the sides have been separated, you should be able to simply lift the cover off of the device.
Use the plastic opening tool to lift the battery off of the back panel. The adhesive used is strong so apply force during removal.
Lift the battery off of the panel gently. This will disconnect the battery connector from the motherboard.
5 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
I just wanted to throw a red flag out there…I broke my connector off the motherboard trying to reinstall the four-pin connection…can anyone advise?
