Zum Hauptinhalt wechseln
Acer Iconia B1-720 Microphone/Speaker Replacement
Was du brauchst
  1. Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: Schritt 1, Bild 1 von 3 Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: Schritt 1, Bild 2 von 3 Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Microphone/Speaker Replacement: Schritt 2, Bild 1 von 3 Acer Iconia B1-720 Microphone/Speaker Replacement: Schritt 2, Bild 2 von 3 Acer Iconia B1-720 Microphone/Speaker Replacement: Schritt 2, Bild 3 von 3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Microphone/Speaker Replacement: Schritt 3, Bild 1 von 2 Acer Iconia B1-720 Microphone/Speaker Replacement: Schritt 3, Bild 2 von 2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: Schritt 4, Bild 1 von 3 Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: Schritt 4, Bild 2 von 3 Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: Schritt 4, Bild 3 von 3
    • Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
    • Tug gently on microphone to remove from slot.
  5. Acer Iconia B1-720 Microphone/Speaker Replacement: Schritt 5, Bild 1 von 2 Acer Iconia B1-720 Microphone/Speaker Replacement: Schritt 5, Bild 2 von 2
    • Unwind the wire from the running channel.
    • To remove microphone, follow same steps.
  6. Acer Iconia B1-720 Microphone/Speaker Replacement: Schritt 6, Bild 1 von 2 Acer Iconia B1-720 Microphone/Speaker Replacement: Schritt 6, Bild 2 von 2
    • Unplug connector from motherboard.
    • Follow same procedure to remove microphone.
    • Unplug the microphone in a similar fashion as with the speaker.
Abschluss
Phillip Keavey
319 Reputation
2 Anleitungen geschrieben
Michigan Tech, Team 1-1, Lauer Spring 2015 Mitglied von Michigan Tech, Team 1-1, Lauer Spring 2015
MTU-LAUER-S15S1G1
2 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 687
