Zum Hauptinhalt wechseln
Acer Iconia B1-A71 LCD Display Replacement
Was du brauchst
Einführungsvideo
  1. Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: Schritt 1, Bild 1 von 3 Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: Schritt 1, Bild 2 von 3 Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: Schritt 1, Bild 3 von 3
    • Switch-off the tablet.
    • If you can't switch it off, use the reset button to do this.
    • With a cutter and a plastic tool remove the back cover.
    • If you have a memory card inside, don't forget to remove it!
  2. Acer Iconia B1-A71 LCD Display Replacement: Schritt 2, Bild 1 von 2 Acer Iconia B1-A71 LCD Display Replacement: Schritt 2, Bild 2 von 2
    • First, disconnect the battery.
    • Now, disconnect the loudspeaker and remove the back cover.
    • Remove all scotch tapes and disconnect the touch screen flex cable...
    • LCD display flex cable,
    • the microphone,
    • and the WiFi and Bluetooth antennas flex cables.
  3. Acer Iconia B1-A71 LCD Display Replacement: Schritt 3, Bild 1 von 3 Acer Iconia B1-A71 LCD Display Replacement: Schritt 3, Bild 2 von 3 Acer Iconia B1-A71 LCD Display Replacement: Schritt 3, Bild 3 von 3
    • Unscrew 5x screws and rmove the main board.
  4. Acer Iconia B1-A71 LCD Display Replacement: Schritt 4, Bild 1 von 3 Acer Iconia B1-A71 LCD Display Replacement: Schritt 4, Bild 2 von 3 Acer Iconia B1-A71 LCD Display Replacement: Schritt 4, Bild 3 von 3
    • The battery is glued to the LCD display metal shield with a double sided adhesive tape.
    • Use plastic tools and carefully remove it.
    • Remove all tapes from the LCD display metal shield.
  5. Acer Iconia B1-A71 LCD Display Replacement: Schritt 5, Bild 1 von 3 Acer Iconia B1-A71 LCD Display Replacement: Schritt 5, Bild 2 von 3 Acer Iconia B1-A71 LCD Display Replacement: Schritt 5, Bild 3 von 3
    • The LCD display is held by metal frame and some locking clips on it.
    • Use a cutter and a plastic tool to separate the LCD.
    • You have to work slowly so as not to break the display.
    • Now, install the new LCD display and reassemble the tablet.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.182 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.519 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 11,025
