Einleitung
If one or both of your cameras are faulty, they can be removed through the use of a plastic opening tool and a Phillips #00 screwdriver.
Was du brauchst
Pry open media port cover at the top of the tablet.
Use the Phillips 00 screwdriver to remove the 1 mm screw.
Using the plastic opening tool gently place the tip of it under the connection and pry up. It will pop out.
Use the plastic opening tool to pry up the rear facing camera. Once removed the front facing camera will come out as well.
