Einleitung
In order to remove the motherboard, you will need both a plastic opening tool and a Phillips #00 screwdriver. In addition to that, all the tape surrounding the motherboard will need to be removed.
Was du brauchst
Open media port cover at the top of the tablet.
Use the Phillips #00 screwdriver to remove the 1 mm screw.
Try to remove the battery by pulling on the blue tabs.
If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out.
Now, disconnect the two smaller black and red cords from the motherboard.
Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
Using the same screwdriver remove the other three screws on the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
The button flex cable retaining clip is broken, do you have this available?
