Einleitung
After the motherboard has been removed, you now have access to the power switch. You will need to use a plastic opening tool to pop the switch out.
Was du brauchst
Open media port cover at the top of the tablet.
Use the Phillips #00 screwdriver to remove the 1 mm screw.
Try to remove the battery by pulling on the blue tabs.
If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out.
Now, disconnect the two smaller black and red cords from the motherboard.
Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
Using the same screwdriver remove the other three screws on the motherboard.
Depress power switch using finger, and simultaneously pry in same direction with a plastic opening tool.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
