Einleitung
After removing the battery, motherboard, and speakers, you can access the screen. Through the use of a Phillips #00 bit and a black plastic spudger, we will show you how to remove the screen.
Was du brauchst
Open media port cover at the top of the tablet.
Use the Phillips #00 screwdriver to remove the 1 mm screw.
Try to remove the battery by pulling on the blue tabs.
If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out.
Now, disconnect the two smaller black and red cords from the motherboard.
Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
Using the same screwdriver remove the other three screws on the motherboard.
Using a plastic spudger pry the square connection away from the screen.
Using the plastic spudger gently pry the screen along the plastic clips.
Once at least 1/2 of the screen is unclipped slide it out of the frame using hands.
14 weitere Nutzer:innen haben diese Anleitung absolviert.
11 Kommentare
nice job people!
It worked! I’m very happy
Fantastic set of instructions. Very much appreciated. Cheers very much!!
