Zum Hauptinhalt wechseln
Acer Iconia One 7 Battery Replacement
Was du brauchst
  1. Acer Iconia One 7 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Begin prying the front from the back on any side of the tablet. Gently work your way around the tablet with the prying tool.
  2. Acer Iconia One 7 Battery Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Battery Replacement: Schritt 3, Bild 1 von 1
    • Turn the tablet over so the battery is facing up.
  4. Acer Iconia One 7 Battery Replacement: Schritt 4, Bild 1 von 2 Acer Iconia One 7 Battery Replacement: Schritt 4, Bild 2 von 2
    • Carefully pull back the black tape covering the battery lead connector.
    • Disconnect connection with the board by pulling up on the wire with the plastic opening tool.
  5. Acer Iconia One 7 Battery Replacement: Schritt 5, Bild 1 von 3 Acer Iconia One 7 Battery Replacement: Schritt 5, Bild 2 von 3 Acer Iconia One 7 Battery Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    • Using a plastic card or opening pick, separate the battery from the rest of the device.
    • Do not use a metal spudger like seen in the example photos. Use a plastic card to avoid bending or rupturing the battery.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 8-5, Eyestone Fall 2015 Mitglied von USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Mitglieder
5 Anleitungen geschrieben
4 Kommentare
is there a replacement batt that can fit here or other brand that can fit? like from samsing tab? acer battery sucks
Stanley So - Antwort
Thank you for this guide, replaced my battery (very easy with guide) and now my tablet works good. Also saved me some money. Thanks
vlamar14 - Antwort
My acer iconia one 7 battery model is 308292 wnd there is no tutorial regarding replacing battery. Thank
wantalktasol - Antwort
Where I can order the new battery part?
melanieloa3 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 18,497
