Zum Hauptinhalt wechseln
Acer Iconia One 7 Front Facing Camera Replacement
Was du brauchst
  1. Acer Iconia One 7 Front Facing Camera Replacement, Front-Facing Camera: Schritt 1, Bild 1 von 1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult, use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Front Facing Camera Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Front Facing Camera Replacement: Schritt 3, Bild 1 von 1
    • Turn tablet over.
    • Locate front-facing camera.
  4. Acer Iconia One 7 Front Facing Camera Replacement: Schritt 4, Bild 1 von 1
    • Pull black tape with front-facing camera.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Michael
519 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 8-5, Eyestone Fall 2015 Mitglied von USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Be carefful when pulling the stick tape. It is very strong and can break the flex cable of the camera and other flex cables...
Egas - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 1,177
