Zum Hauptinhalt wechseln
Acer Iconia One 7 Motherboard Replacement
Was du brauchst
    • Reminder: Turn off device before you start opening your tablet.
  1. Acer Iconia One 7 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Use caution when prying the lid open to avoid damaging your tablet.
  2. Acer Iconia One 7 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Using a plastic opening tool, separate the back cover from the main device
    • Open each side continuously to ensure all sides have been separated,
  3. Acer Iconia One 7 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Turn tablet over.
    • Lay the tablet on a flat surface with the screen facing down. Locate the copper cover along the outside of the tablet.
  4. Acer Iconia One 7 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Carefully peel back the copper foil to reveal the motherboard.
  5. Acer Iconia One 7 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Peel tape back to expose connections.
  6. Acer Iconia One 7 Motherboard Replacement: Schritt 7, Bild 1 von 2 Acer Iconia One 7 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • There are several sets of wires connected to the motherboard as shown in the images. Carefully disconnect each set of wires.
  7. Acer Iconia One 7 Motherboard Replacement: Schritt 8, Bild 1 von 2 Acer Iconia One 7 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Use a JIS screw bit #00 to remove screws around the motherboard using the provided image to locate each screw.
  8. Acer Iconia One 7 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Gently pull out motherboard.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Michael
519 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 8-5, Eyestone Fall 2015 Mitglied von USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 2,597
