Zum Hauptinhalt wechseln
Acer Iconia One 7 Rear-Facing Camera Replacement
Was du brauchst
  1. Acer Iconia One 7 Rear-Facing Camera Replacement, Rear-Facing Camera: Schritt 1, Bild 1 von 1
    • Begin at any side of the tablet.
    • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
    • Prying the lid open can be difficult, use caution in order to safely remove.
    • Turn off device before this step.
  2. Acer Iconia One 7 Rear-Facing Camera Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic opening tool, separate the back cover from the main device.
    • Open each side continuously to ensure all sides have been separated.
  3. Acer Iconia One 7 Rear-Facing Camera Replacement: Schritt 3, Bild 1 von 1
    • Turn the tablet over to locate the camera on the top left.
    • Besides the parts that are mentioned in the instruction, try not to agitate other fragile components inside the device.
  4. Acer Iconia One 7 Rear-Facing Camera Replacement: Schritt 4, Bild 1 von 2 Acer Iconia One 7 Rear-Facing Camera Replacement: Schritt 4, Bild 2 von 2
    • Peel black tape.
    • Detach clip from motherboard.
  5. Acer Iconia One 7 Rear-Facing Camera Replacement: Schritt 5, Bild 1 von 2 Acer Iconia One 7 Rear-Facing Camera Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Take out film object using tweezers.
    • Using tweezers take out camera.
Abschluss
Michael
519 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 8-5, Eyestone Fall 2015 Mitglied von USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
How to get new camera if the original camera is damaged
Prakash Hasabnis - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 427
