Einleitung
We dismantled the Acer Iconia One 7 and found it to be extremely repairable with only 8 components.
Ersatzteile
Keine Ersatzteile angegeben.
Entry method is to remove the rear bathtub case, the seal is easy to break with opening tools.
The bathtub case is attached to the front display panel by soft plastic clips and without adhesive.
The battery cable runs short and requires a careful and precise wiggle to remove its connection from the motherboard.
Only two adhesive pull tabs secure the battery. This is preferred over adhesive which requires heat and prying to separate.
Layer of components removable upon opening: power/volume button cable, loudspeaker.
The power/volume button cable is lightly secured with adhesive.
Two Phillips #0 screws secure the loudspeaker housing.
The display, digitizer, and camera cables can be disconnected without removing the motherboard.
The motherboard is secured to the display frame by three Phillips #0 screws.
The Micro-USB port, headphone jack and microphone are soldered to the motherboard. These are common failure points and it would be better if they could be individually replaced.
The front and rear camera are tethered and will need to be replaced together if one where to fail.
The digitizer is fused to the front case but the LCD display can be isolated by unclipping it from the assembly with an opening tool.
The Acer Iconia One 7 earns an 8 out of 10 on our repairability scale (10 is the easiest to repair):
LCD and front glass are not fused and can be replaced individually.
Battery is easy to replace.
Modular design allows replacement of many individual parts.
Standard Phillips screws used throughout.
High wear components soldered in place, which increases replacement costs.
Manufacturer does not provide user-accessible repair documentation.
7 weitere Nutzer haben diese Anleitung absolviert.
5 Kommentare
I have an Acer Iconia tablet A500, 32GB RAM, 1GB ROM
I would like to increase my ROM to 4GB ROM, is it possible.
Can you recommend someone or a place that can do this for me?
Thanks, Ginger
email address: ginger41558@outlook.com
I have used it very little, sat quietly in a drawer - when I decided to use it, it won’t power up! Sometimes it shows a splash screen with one word on it - ACER (if I remember right). Any idea what might be going on, I’d be grateful - would even give it to someone to revive and use
Estuvo excelente. Gracias y saludos.
Is this Acer Iconia One 7 B1-780 (2017) or the older 2014 version?
