Zum Hauptinhalt wechseln
Acer Iconia One 8 Battery Replacement
Was du brauchst
  1. Acer Iconia One 8 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Iconia One 8 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • To remove the back panel, insert an opening tool into the small crack between the screen and back panel. Gently pry open the tablet.
  2. Acer Iconia One 8 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the black piece of tape that is holding the red, yellow, and white wires in place.
  3. Acer Iconia One 8 Battery Replacement: Schritt 3, Bild 1 von 1
    • Once the tape has been removed, gently pinch the wires and remove them from the socket. They should come out easily.
  4. Acer Iconia One 8 Battery Replacement: Schritt 4, Bild 1 von 1
    • Carefully work a plastic spudger underneath the battery and pry it free.
    • Use an iOpener or carefully apply heat with a heat gun to soften the adhesive under the battery.
    • Be careful not to bend or puncture the battery.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Josh Cooper
319 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 2,929
