Einleitung
In order to replace the camera you'll have to first remove the back cover. The camera is one of the easiest components to replace once the cover is removed.
Was du brauchst
Power off the device
Remove any cables that might be connected to your device
Make sure the device is placed on a flat surface with the display screen facing up
Fast fertig!
Abschluss
