Einleitung
The camera is one the simplest components to replace once the back cover is removed. The important thing to remember here is to take your time removing the cover.
Was du brauchst
Power off the device
Remove any cables that might be connected to your device
Make sure the device is placed on a flat surface with the display screen facing up
Use the precision tweezers to carefully pull out the connector and remove the camera.
