Zum Hauptinhalt wechseln
Acer Iconia Tab 8 A1-860 Battery Replacement
Was du brauchst
  1. Acer Iconia Tab 8 A1-860 Battery Replacement, Rear Case: Schritt 1, Bild 1 von 2 Acer Iconia Tab 8 A1-860 Battery Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Insert the plastic opening tool into the seam between the back case and the display.
    • Work the plastic opening tool around the seam until the rear case separates from the display.
  2. Acer Iconia Tab 8 A1-860 Battery Replacement: Schritt 2, Bild 1 von 1
    • Separate the rear case and place the tablet face side down.
  3. Acer Iconia Tab 8 A1-860 Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Using a spudger, work the tool under the battery connector located above the battery on the left side, and lift it free.
  4. Acer Iconia Tab 8 A1-860 Battery Replacement: Schritt 4, Bild 1 von 3 Acer Iconia Tab 8 A1-860 Battery Replacement: Schritt 4, Bild 2 von 3 Acer Iconia Tab 8 A1-860 Battery Replacement: Schritt 4, Bild 3 von 3
    • Pull firmly on the black tabs, located at the top left and bottom right of the battery.
    • The clear adhesive strips attached to the tabs are quite stretchy. Don't give up; keep pulling the tabs until the battery releases. The strips will not be reusable.
    • Remove the battery.
Abschluss
Stephanie Nelson
101 Reputation
1 Anleitung geschrieben
iFixit, Team 1-1, Suovanen Spring 2016 Mitglied von iFixit, Team 1-1, Suovanen Spring 2016
FIX-SUOVANEN-S16S1G1
3 Mitglieder
2 Kommentare
The model I worked on has two flat black bands running across the battery from one side to the other. They appear to be wiring connecting each side of the electronics because they are connected to sockets on both sides. Didn't want to proceed until I have more info. I have a jpg of the setup if that would help anyone (or would help me).
Keith Riggs - Antwort
Is this identical to the 8 A1 850? Not finding any instructions or videos on that particular model. I can’t see a notch or anything to use as a starting point to open the tablet. Where and how do you start to open it?
David - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 4,962
