Zum Hauptinhalt wechseln
Acer Iconia Tab 8 A1-860 Speaker Replacement
Was du brauchst
  1. Acer Iconia Tab 8 A1-860 Speaker Replacement, Rear Case: Schritt 1, Bild 1 von 2 Acer Iconia Tab 8 A1-860 Speaker Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Insert the plastic opening tool into the seam between the back case and the display.
    • Work the plastic opening tool around the seam until the rear case separates from the display.
  2. Acer Iconia Tab 8 A1-860 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Separate the rear case and place the tablet face side down.
  3. Acer Iconia Tab 8 A1-860 Speaker Replacement, Battery: Schritt 3, Bild 1 von 1
    • Using a spudger, work the tool under the battery connector located above the battery on the left side, and lift it free.
  4. Acer Iconia Tab 8 A1-860 Speaker Replacement: Schritt 4, Bild 1 von 3 Acer Iconia Tab 8 A1-860 Speaker Replacement: Schritt 4, Bild 2 von 3 Acer Iconia Tab 8 A1-860 Speaker Replacement: Schritt 4, Bild 3 von 3
    • Pull firmly on the black tabs, located at the top left and bottom right of the battery.
    • The clear adhesive strips attached to the tabs are quite stretchy. Don't give up; keep pulling the tabs until the battery releases. The strips will not be reusable.
    • Remove the battery.
  5. Acer Iconia Tab 8 A1-860 Speaker Replacement, Speaker: Schritt 5, Bild 1 von 2 Acer Iconia Tab 8 A1-860 Speaker Replacement, Speaker: Schritt 5, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove the three 3 mm screws.
  6. Acer Iconia Tab 8 A1-860 Speaker Replacement: Schritt 6, Bild 1 von 2 Acer Iconia Tab 8 A1-860 Speaker Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to gently lift off the connector and wires attached to the speakers.
    • Remove the speakers from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
IUPUI, Team S2-G3, Harley Spring 2019 Mitglied von IUPUI, Team S2-G3, Harley Spring 2019
IUPUI-HARLEY-S19S2G3
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 144
