Einleitung
The Acer Iconia Tab uses a Li-Po 3260 mAh battery that is screwed into the device.
Was du brauchst
With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
Using a Phillips #00 screwdriver remove the 4.0 mm screws on the sides of the tablet.
Once the 4 screws have been removed use the plastic opening tool to pry open the device on the side of the device.
After prying open the case with the plastic opening tool carefully remove the case from the device and place the device face down on its screen.
Using a Phillips #00 screwdriver remove the 4.0 mm screws holding the battery in place.
Lift the battery out of the device, and disconnect the cable attached to the motherboard by pulling it out to the side not lifting it up.
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare
Instructions should point out that when removing the device from the case that prying tool must got between the gasket and plastic case, NOT between the screen and the gasket. I hope my cracked screen will still work!
What are the specifications to purchase a new battery for my icona Acer tablet 200 ?
