Zum Hauptinhalt wechseln
Acer Iconia Tab A200 Microphone Replacement
Was du brauchst
  1. Acer Iconia Tab A200 Microphone Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Iconia Tab A200 Microphone Replacement, Battery: Schritt 1, Bild 2 von 2
    • With the plastic opening tool pry open the grey plastic siding on both sides of the tablet.
  2. Acer Iconia Tab A200 Microphone Replacement: Schritt 2, Bild 1 von 2 Acer Iconia Tab A200 Microphone Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws on the sides of the tablet.
    • There are two screws on each side of the tablet that need to be removed before the back casing can be removed.
  3. Acer Iconia Tab A200 Microphone Replacement: Schritt 3, Bild 1 von 2 Acer Iconia Tab A200 Microphone Replacement: Schritt 3, Bild 2 von 2
    • Once the 4 screws have been removed use the plastic opening tool to pry open the device on the side of the device.
    • Be careful prying on the sides where you removed the screw as the plastic casing is not very strong and may break.
    • After prying open the case with the plastic opening tool carefully remove the case from the device and place the device face down on its screen.
  4. Acer Iconia Tab A200 Microphone Replacement: Schritt 4, Bild 1 von 2 Acer Iconia Tab A200 Microphone Replacement: Schritt 4, Bild 2 von 2
    • Using a Phillips #00 screwdriver remove the 4.0 mm screws holding the battery in place.
  5. Acer Iconia Tab A200 Microphone Replacement: Schritt 5, Bild 1 von 2 Acer Iconia Tab A200 Microphone Replacement: Schritt 5, Bild 2 von 2
    • Lift the battery out of the device, and disconnect the cable attached to the motherboard by pulling it out to the side not lifting it up.
  6. Acer Iconia Tab A200 Microphone Replacement, Microphone: Schritt 6, Bild 1 von 2 Acer Iconia Tab A200 Microphone Replacement, Microphone: Schritt 6, Bild 2 von 2
    • Lift up on the microphone cable to lift the microphone component away from the case.
  7. Acer Iconia Tab A200 Microphone Replacement: Schritt 7, Bild 1 von 1
    • Once the microphone has been lifted away from the case, disconnect the microphone cable from the motherboard by pulling the cable out horizontally. Do not lift up to remove.
Abschluss
Jaimie Payne
477 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 5-5, Landers Spring 2016 Mitglied von UMass Dartmouth, Team 5-5, Landers Spring 2016
UMASSD-LANDERS-S16S5G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 159
