Einleitung
This repair guide will help you with replacing the back case on your Acer Iconia Tab A500. The back case can be replaced if it's damaged or for personal reasons as well.
Was du brauchst
To start, gently separate one corner of the case using the black spudger.
Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
11 weitere Personen haben diese Anleitung absolviert.
