Einleitung
The Docking port is used to connect accessories like keyboards with the device. Follow the steps in the guide to replace the existing docking port on the device.
Was du brauchst
Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
Continue separating the back cover along the short side closest to the camera and around the device.
When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
In diesem Schritt verwendetes Werkzeug:Tweezers$3.99
Use the angled tweezers to disconnect the white motherboard-battery connector in the middle of the side opposite the docking port.
Use the plastic opening tool to flip up the locking mechanism for the ribbon cable on the docking port board that is flat, white, and folded.
Detach the folded, white ribbon cable on the docking port board.
Use a Phillips #1 screwdriver to unscrew the three 3.0 mm Philips head screws holding the docking port in place.
