Einleitung
The motherboard directly connects almost all of a device’s parts. If your motherboard is having problems or has failed, you may decide to replace it. This guide will demonstrate replacing a motherboard for the Acer Iconia Tab A501.
Was du brauchst
Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
Continue separating the back cover along the short side closest to the camera and around the device.
When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
In diesem Schritt verwendetes Werkzeug:Tweezers$3.99
Use the angled tweezers to disconnect the motherboard-battery cable from the white connector in the middle of the side opposite the docking port.
Use a Phillips #1 screwdriver to remove the four 4.0 mm Philips head screws connecting the battery to the motherboard.
Take out the battery.
Use the plastic opening tool to flip up the locking mechanism on the motherboard connected to the folded, white ribbon cable.
Remove the folded, white cable.
Use the plastic opening tool to flip up the locking mechanism on the motherboard connected to the straight, white ribbon cable.
Remove the straight, white ribbon cable.
Use the angled tweezers to disconnect the cable with red, white and green wires from the beige connector slightly in from the docking port.
Unscrew the 3.0 mm Phillips head screw on the speaker near the Micro-HDMI port using a Phillips #1 screwdriver.
Unscrew the 4.0 mm Phillips head screw on the speaker near the Micro-HDMI port using a Phillips #1 screwdriver.
Remove the speaker.
Use the flat end of the standard Spudger to disconnect the two small, rotatable connectors attached to the wireless adapter.
Use a Phillips #1 screwdriver to remove the two 3.0 mm Philips head screws holding the adapter down.
Use the wide end of the standard Spudger to take off the rotatable connector to the 3g antenna below the rear-facing camera.
Use the angled tweezers to disconnect the cable with red wires from the beige connector opposite the docking port.
Use the angled tweezers to disconnect two microphone connectors, which are above the orange-brown touchscreen connector and next to the battery space.
Use the plastic opening tool to flip up the locking mechanism to the white front camera port just above the rear-facing camera.
Disconnect the camera cable from the motherboard.
Use the wide, flat end of the standard Spudger to disconnect the display connector from the large, metal port next to the battery space.
Use a Phillips #1 screwdriver to unscrew the four 4.0 mm Phillips head screws holding the motherboard in place.
