Zum Hauptinhalt wechseln
Acer Iconia Tab A501 Speaker Replacement
Was du brauchst
  1. Acer Iconia Tab A501 Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 3 Acer Iconia Tab A501 Speaker Replacement, Back Cover: Schritt 1, Bild 2 von 3 Acer Iconia Tab A501 Speaker Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
  2. Acer Iconia Tab A501 Speaker Replacement: Schritt 2, Bild 1 von 1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
  3. Acer Iconia Tab A501 Speaker Replacement, Speaker: Schritt 3, Bild 1 von 3 Acer Iconia Tab A501 Speaker Replacement, Speaker: Schritt 3, Bild 2 von 3 Acer Iconia Tab A501 Speaker Replacement, Speaker: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    $3.99
    • In the next step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the white motherboard-battery connector in the middle of the side opposite the docking port.
  4. Acer Iconia Tab A501 Speaker Replacement: Schritt 4, Bild 1 von 3 Acer Iconia Tab A501 Speaker Replacement: Schritt 4, Bild 2 von 3 Acer Iconia Tab A501 Speaker Replacement: Schritt 4, Bild 3 von 3
    • In this step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the cable with red, white and green wires from the beige connector slightly toward the side with the Micro-HDMI port relative to the docking port.
  5. Acer Iconia Tab A501 Speaker Replacement: Schritt 5, Bild 1 von 3 Acer Iconia Tab A501 Speaker Replacement: Schritt 5, Bild 2 von 3 Acer Iconia Tab A501 Speaker Replacement: Schritt 5, Bild 3 von 3
    • Unscrew the 3.0 mm Phillips head screw on each speaker using a Phillips #1 screwdriver.
    • Unscrew the 4.0 mm Phillips head screw on each speaker using a Phillips #1 screwdriver.
  6. Acer Iconia Tab A501 Speaker Replacement: Schritt 6, Bild 1 von 3 Acer Iconia Tab A501 Speaker Replacement: Schritt 6, Bild 2 von 3 Acer Iconia Tab A501 Speaker Replacement: Schritt 6, Bild 3 von 3
    • Remove the speakers.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 150
