Zum Hauptinhalt wechseln
Acer Iconia Tab A501 Touch Screen/Glass Replacement
Was du brauchst
  1. Acer Iconia Tab A501 Touch Screen/Glass  Replacement, Back Cover: Schritt 1, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement, Back Cover: Schritt 1, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
  2. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 2, Bild 1 von 1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
  3. Acer Iconia Tab A501 Touch Screen/Glass  Replacement, Display: Schritt 3, Bild 1 von 1
    • Remove all tape from the device.
  4. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 4, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 4, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    $3.99
    • In the next step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the motherboard-battery cable from the white connector in the middle of the side opposite the docking port.
  5. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 5, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 5, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 5, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the four 4.0 mm Philips head screws connecting the battery to the motherboard.
    • Take out the battery.
  6. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 6, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 6, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 6, Bild 3 von 3
    • Use the plastic opening tool to flip up the locking mechanism on the motherboard connected to the folded, white ribbon cable.
    • Remove the folded, white cable.
  7. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 7, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 7, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 7, Bild 3 von 3
    • Use a Phillips #1 screwdriver to unscrew the three 3.0 mm Philips head screws holding the docking port in place.
    • Remove the docking port.
  8. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 8, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 8, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 8, Bild 3 von 3
    • In this step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the cable with red, white and green wires from the beige connector slightly in from the docking port.
  9. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 9, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 9, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 9, Bild 3 von 3
    • Unscrew the 3.0 mm Phillips head screw on each speaker using a Phillips #1 screwdriver.
    • Unscrew the 4.0 mm Phillips head screw on each speaker using a Phillips #1 screwdriver.
  10. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 10, Bild 1 von 2 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 10, Bild 2 von 2
    • Remove the speakers.
  11. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 11, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 11, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 11, Bild 3 von 3
    • Use the plastic opening tool to flip up the locking mechanism on the motherboard connected to the straight, white ribbon cable.
    • Remove the straight, white ribbon cable.
  12. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 12, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 12, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 12, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the two 4.0 mm Philips screws attaching the metal plate, USB board, and device.
    • Remove the metal plate.
  13. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 13, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 13, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 13, Bild 3 von 3
    Halberd Spudger
    $2.99
  14. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 14, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 14, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 14, Bild 3 von 3
    • Use care in the next step.
    • Use the wide, flat end of the standard Spudger to disconnect the display connector from the large, metal port next to the battery space.
  15. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 15, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 15, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 15, Bild 3 von 3
    • Use the flat end of the standard Spudger to disconnect the two small, rotatable connectors attached to the wireless adapter.
  16. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 16, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 16, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 16, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the two 3.0 mm Philips head screws holding the adapter down.
  17. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 17, Bild 1 von 2 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 17, Bild 2 von 2
    • Carefully slide the adapter out to remove it.
  18. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 18, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 18, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 18, Bild 3 von 3
    • Use the wide end of the standard Spudger to take off the rotatable connector to the 3g antenna below the rear-facing camera.
  19. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 19, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 19, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 19, Bild 3 von 3
    • Use the angled tweezers to disconnect the cable with red wires from the beige connector opposite the docking port.
  20. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 20, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 20, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 20, Bild 3 von 3
    • The charging port may be taped from underneath and need a bit of force to take out.
    • Use the angled tweezers to remove the charging port.
  21. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 21, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 21, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 21, Bild 3 von 3
    • Use the tweezers to remove the white touchscreen connector with multi-colored wires from the black port just below the power buttons on the motherboard.
  22. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 22, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 22, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 22, Bild 3 von 3
    • Use the plastic opening tool to flip up the locking mechanism for the wide, white port for the thin, orange-brown touchscreen cable just above the charging port.
    • Remove the touchscreen board.
  23. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 23, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 23, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 23, Bild 3 von 3
    • Use the angled tweezers to disconnect two microphone connectors, which are above the orange-brown touchscreen connector and next to the battery space.
  24. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 24, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 24, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 24, Bild 3 von 3
    • Use the plastic opening tool to flip up the locking mechanism to the white front camera port just above the rear-facing camera.
    • Disconnect the camera cable from the motherboard.
  25. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 25, Bild 1 von 2 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 25, Bild 2 von 2
    • Use a Phillips #1 screwdriver to unscrew the four 4.0 mm Phillips head screws holding the motherboard in place.
  26. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 26, Bild 1 von 2 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 26, Bild 2 von 2
    • Remove the motherboard.
  27. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 27, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 27, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 27, Bild 3 von 3
    • Remove the two microphones in the middle of the side opposite the docking port.
  28. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 28, Bild 1 von 2 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 28, Bild 2 von 2
    • Use the Phillips #1 screwdriver to unscrew the 3.0 mm Phillips head screw holding the thin metal plate to the device near the Micro-HDMI port.
    • Use the Phillips #1 screwdriver to unscrew the 4.0 mm Phillips head screw near the orange-brown touchscreen cable.
  29. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 29, Bild 1 von 2 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 29, Bild 2 von 2
    • Move all wires off of the thin, metal plate.
  30. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 30, Bild 1 von 1
  31. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 31, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 31, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 31, Bild 3 von 3
    • The antennae in the next step are attached with adhesive.
    • Remove the three antennae along the shorter sides of the device.
  32. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 32, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 32, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 32, Bild 3 von 3
    • Carefully insert the Jimmy between the display and the glass to break the glue seal.
    • Move the Jimmy all the way around the device.
  33. Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 33, Bild 1 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 33, Bild 2 von 3 Acer Iconia Tab A501 Touch Screen/Glass  Replacement: Schritt 33, Bild 3 von 3
    • Continue moving the Jimmy around the device until the glue no longer holds the display in place.
    • Remove the display.
  34. Acer Iconia Tab A501 Touch Screen/Glass  Replacement, Touch Screen/Glass: Schritt 34, Bild 1 von 2 Acer Iconia Tab A501 Touch Screen/Glass  Replacement, Touch Screen/Glass: Schritt 34, Bild 2 von 2
    • Use the Jimmy to carefully remove the front camera from the front cover of the tablet.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 293
