Einleitung
The wireless adapter is needed to connect to the Wi-Fi network or mobile network. This guide will demonstrate the wireless adapter replacement for the Acer Iconia Tab A501.
Was du brauchst
Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
Continue separating the back cover along the short side closest to the camera and around the device.
When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
Use the angled tweezers to disconnect the motherboard-battery cable from the white connector in the middle of the side opposite the docking port.
Use the flat end of the standard Spudger to disconnect the two small rotatable connectors attached to the wireless adapter.
Use a Phillips #1 screwdriver to remove the two 3.0 mm Philips head screws holding the adapter down.
