Einleitung
In this guide we will show you how to replace the battery for the Acer Iconia W3-810. This is for the situation of a faulty battery power cord or a no longer functioning battery.
Was du brauchst
Place the tablet face down on a flat surface with the charger facing toward you.
Pull the ribbon cord by pushing the clamp on the port toward you with the plastic opening tool.
Use the plastic opening tool to carefully slide the power cord from its slot by pushing it out from both sides, then remove the cord from its port with your hand.
Pull on the ribbon cord carefully in order to break the seal between the ribbon cord and the battery. Do this until the cord is completely free of the battery.
Use the plastic opening tool to gently wedge out and lift the battery pack from the device.
Carefully break the bond between the inner tape and the battery using the plastic opening tool. The tape can be found in the middle and either side of the battery.
3 weitere Personen haben diese Anleitung absolviert.
