Einleitung
Picks up after the back pannel and battery guides, this will show you how to remove and replace the rear facing camera incase of failure. This may need to be replaced in cases of damage to the device.
Was du brauchst
Place the tablet face down on a flat surface with the charger facing toward you.
Lift the retaining flap fastening the ribbon cord to the motherboard using a plastic opening tool.
Abschluss
