Einleitung
The tablet and the dock use the same battery. This guide shows how to remove the battery from the dock/keyboard.
Was du brauchst
Remove the two 6.6mmT6 Torx screws near the hinge.
Remove the four 3.6mm T6 Torx screws on either side.
Using an Xacto knife, peel the rubber strip back far enough on either end to expose the two screws.
Remove the two 4.5mm Phillips screws.
Using the two tabs on either side of the connector, unplug the battery.
Two strips of adhesive on either side hold the battery in place.
Use a flexible piece of plastic to slice the strip of adhesive on one side.
Leave the plastic in place when doing the other side.
